Solved Listen to own recording (3CX Softphone)
Discussion in '3CX Phone System - General' started by MSmeets, Nov 2, 2017.
  1. MSmeets
    Sep 25, 2017
    32
    I enabled Extension recordings.
    From the admin console / dashboard i can download recording.
    But can a user also listen to the recording? I only have the option 'delete recording' , I can not find 'listen to recording' (from the softphone)
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @MSmeets
    Please navigate to extension settings / Phone Provisioning and choose the 3CX client from the drop down menu. Scroll down to "Access" and make sure that the option "Show Call Recordings" option is enabled. Then navigate to the 3CX client, click on settings and the Recordings. You should be able to see the recording there and the option to play it on the phone.
  3. MSmeets
    Sep 25, 2017
    32
    Thank you very much, it is working!
    Why I have to set right in tab 'provisioning' instead of tab RIGHTS ??? strange but true
    And I hoped I could listen to the recordings from the HISTORY button...instead going to SETTINGS, RECORDINGS.....also very very strange
    I have to create a manual to send to my clients, because this is not easy to understand
  4. YiannisH_3CX
    May 10, 2016
    4,349
    274
    Glad to hear it is working and thank you for the feedback
