Listen to voice message from other extension..
Discussion in '3CX Phone System - General' started by seroban, Jan 7, 2009.
  1. seroban
    Jan 7, 2009
    Could somebody please give me some hints?
    I have a system with 7 extensions and only uses voice message for one of the extensions.
    My extensions is two digits.
    What I want to to is to be able to listen to voice messages from any of the extensions. When dialing 99 I am instructed to enter extension number but the system does not take the extension, it only ask me over and over again for extension number. If I choose for example extension 100 (even if I have two digit extensions) it says extension not found. If I dial the 99 at the extension were the voice message is saved it works but not for the other extensions.
    Is this a bug? Do I have to use 3 digit extension numbers?
    //Robert :roll:
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    This issue has been identified and will be fixed with a service release which will be out next week.
    regards
