Solved Listen to voicemail of another extension
Discussion in '3CX Phone System - General' started by jwardlaw93, Mar 12, 2018.
  1. jwardlaw93
    Mar 9, 2018
    14
    I have a client that needs to have access to the voicemail of a separate extension. (Ext 105 needs to frequently access the voicemail of 106.)
    Is there a star code or easier way of doing this?
    Thanks for the help.
    10,744
    281
    #2 leejor, Mar 12, 2018
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,098
    166
    As above,
    Note if extension 106 has deleted the voicemail, 105 will not be able to hear it
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Hello @jwardlaw93
    Please note that if you call the voicemail service from any extension then you will be prompt for your pin number. If you however hit # before entering your pin then the voicemail service will then ask you for an extension number. If you know the pin of the extension you want to access then you can just enter the extension number and the pin.
  5. jwardlaw93
    Mar 9, 2018
    14
    Thank you all, I was able to train the users to press the voicemail button, followed by the # key and the extension.
    YiannisH_3CX likes this.
  6. YiannisH_3CX
    May 10, 2016
    6,016
    420
    Glad to see that a solution was found and thank you for sharing your solution
