Listening in from across the Atlantic on calls
Discussion in '3CX Phone System - General' started by nigelmac, Oct 3, 2011.
  1. nigelmac
    Oct 3, 2011
    I have a 5 user call centre set up in London.
    I now have a requirement for a senior manager of the parent company in Canada to listen to calls in real time.
    I dont mind a bit of lag from the distance (as the manager will only be listening)
    Any ideas how easy this is to set up.....
    The PCs are all Windows 7 Pro on a 2008 Server setup with Plantronics headsets
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    If you have the call center edition license its just a mouse click away on MyPhone.
