Little Bug in Extension Configuration
Discussion in '3CX Phone System - General' started by bluenetwork, Jun 21, 2010.
  1. bluenetwork
    Oct 23, 2009
    10
    When I decativate the voice mail for an extension the input box for the pin number is deactivated too. Because the pin is also used for the assistant and for the myphone portal, the field should remain active.
    It ist not a new behaviour but it would be great if you can fix it in version 9.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,500
    98
    Deactivating the VoiceMail will not deactivate your PIN Number in any way.
    You can still use that same PIN Number to login to the Assistant.
    The only inconvenience i see for the user is that in order to modify his pin, he will need to enable the voicemail tab temporarily.
    I will see what can be done about this.
