Little problem with bluetooth
Discussion in 'Android' started by LeDob, Aug 7, 2011.
  1. LeDob
    Aug 7, 2011
    7
    Hello everybody !!!!!!!!!!!!!!!!!!!!!!!
    When I use bluetooth headset it does not work when i select bluetooth.
    To use the bluetooth I have to change the audio parameters and save its then I can ear on the bluetooth headset.
    When I run again 3CX I have to do the change and save audio parameters each time :( :(
  2. StefanW
    Jun 2, 2009
    1,230
    95
    the Android version does have no support for now for any connected BT devices
