Live streaming hold music.
Discussion in 'Windows' started by seeker2921, Nov 15, 2008.
  1. seeker2921
    Nov 10, 2008
    I'm not sure if this is even possible to do. But Id like to have the hold music be something that is streaming live. If anyone has any ideas on how to do this or if its even possible that would be great. Thanks for any input you may have on this.
    Steven
  2. Discovery Technology
    Apr 19, 2008
    278
    Hi Steven,
    Take a look at the following post - this should give you some tips on how to set this up.
    http://www.3cx.com/forums/3cx-vs-trixbox-4365-30.html#p20291
    Brendan
