Load Balance Broadband Router TL-R470T+
Discussion in '3CX Phone System - General' started by bobptr, Nov 15, 2017.
  1. bobptr
    Nov 15, 2017
    Hi I am using a Local Balancing Router, it has 2 ADSL connections feeding it and one LAN output feeding the network computers, I am have trouble getting the 3cx webclient to work on the LAN, if I connect a computer to each of the ADSL Routers then it works fine but not on the output of the Local Balancing Router feeding the LAN, can any one advise me on this, by the way I am using a cloud 3cx, my webclient works fine from my home just not as this one locations that has the additional router. Also there is voip already working fine through the router eg a soft phone, just not the webclient
    thanks in advance
    bob
