Load Generator / Stress test
Discussion in '3CX Phone System - General' started by 3CXusername, Jul 31, 2014.
  1. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Good day,
    What is the best way to stress test a 3CX implementation?
    thanks
    11,071
    323
    This will vary, to a great deal from one installation to another. A simple call from one internal extension to another, if the call audio does not pass through the PBX, puts very little load as compared to, perhaps, a trunk call, one where the audio is forced to pass through the PBX, or, transcoding is involved. Recording of calls, or use of voicemail, and extensive use of features such as IVR's and queues could also affect performance in varying degrees. Unless you are attempting to run 3CX on a "budget" system, then I would think that most recent model, decent quality, servers, or high ender PC's shouldn't have a problem. if you have a specific hardware configuration in mind, post the details and you will no doubt get some comments.
    If you provided more information on the set-up in question (extension, trunk details), then someone with something similar, might be able to provide the load figures, that they have experienced.
  3. 3CXusername
    Jul 31, 2014
    183
    16
    Thanks for the reply.
    I was hoping for some type of call simulator.
    I am supporting 125 extensions and less than 32 simultaneous calls.
    Following the 3CX published guidelines here is my configuration:
    o 3CXserver v12 SP6 (on VMware 5.5)
     O/S: Windows 2k8 R2 Standard x64
     CPU: 2x vCPU
     MEM: 4GB
     vNIC: VMXNET3
    Suppose you can always add more horsepower but any concerns?
