Local Contact Backup Feature Not Working
Discussion in '3CX Phone System - General' started by garn, Aug 24, 2017.
  1. garn
    Jul 17, 2017
    24
    I have Yealink T46G's with this feature and it is not working. Anyone else try to utilize this with success?
    Have the following config in my provisioning file:
    Code:
    static.auto_provision.local_contact.backup.enable = 1
    static.auto_provision.local_contact.backup.path = %%PROVLINK%%/LocalContacts/%%mac_address%%-contacts.xml
    No files are ever found in that location after editing local contacts with this provisioned setting.
  2. garn
    Jul 17, 2017
    24
