Local or Remote Detection
Discussion in 'Android' started by EduTech, Nov 15, 2017.
  1. EduTech
    Sep 21, 2017
    We have 3CX hosted internally and phones are on their own VLAN. We also have a BYOD WiFi VLAN that id like users to be bale to use the client app on.
    The trouble i am having is that when connected to the wifi, there is no audio when calling internal phones - the cleint doesn't use the tunnel and so as SIP is not open between the VLANS, their is no audio.
    What do I need to do to force the clients to connect over the tunnel when connected to our BYOD wifi. Or in other words, how can i prevent devices connected to the BYOD from thinking they are locally connected to the PBX.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,526
    71
    The raw solution - on the client side - is to clear the Local PBX IP field in account settings.
