Lock 3CX soft-phone in Auto-Answer mode.
Discussion in 'Windows' started by Panos Tsapralis, Aug 17, 2012.
  1. Panos Tsapralis
    Aug 17, 2012
    I would like to configure the 3cx soft-phone so that it always operates in Auto-Answer mode and my users be unable to switch to DND or any other mode. Is there a way to do this (in the form of some registry value or an entry in some configuration file)?
    TIA,
    Panos Tsapralis,
    Athens, GREECE.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,544
    298
    Are you trying to use these for a Call Center type environment? I like the idea... Maybe being able to lock it down via an Admin Password or something...
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I no of no way to do that using 3cx softphone.
