Lock down ring groups
Discussion in '3CX Phone System - General' started by kmanson, Sep 26, 2012.
  1. kmanson
    Sep 26, 2012
    8
    I might be missing it, but how can i lock down a paging ring group from the outside? Right now if you dial-in and enter the ring group at the greeting it allows anyone to announce.
    Version 3CX V11 SP1
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    Go to Custom Parameters from Advanced settings menu and search for IVRDONOTCALL. You can set from here the numbers that you don't want to be dialed from IVR.
  3. kmanson
    Sep 26, 2012
    8
    For anyone else that reads this thread in the future, after entering the extension to Custom Parameters you need to restart the services for it to take effect. Other than that it worked great :p
