Solved Locked Out
Discussion in '3CX Phone System - General' started by Andy Veal, Jan 8, 2018.
  1. Andy Veal
    Oct 5, 2017
    60
    Was logged into the PBX viewing extensions and rights and was then logged out and told that I was locked out due to too many failed login attempts.
    Andy V
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Andy Veal
    This means that the ip of the specific connection is blocked by the PBX. This could happen either by Management Console failed login tries or even by a phone behind that IP failing to register with the PBX. Try connecting from a different connection/IP and remove the blacklisted IP from Dashboard>> IP Blacklist
  3. Andy Veal
    Oct 5, 2017
    60
  4. mariosM_3CX
    Nov 1, 2017
    406
    38
    No problem, glad to help
  5. Alvin Maverick Cruz
    Jan 11, 2018
    Welcome to the 3CX Management Console
    Login access denied. Too many incorrect login attempts. Try later or contact the Administrator.
  6. Alvin Maverick Cruz
    Jan 11, 2018
    I was trying it out
  7. mariosM_3CX
    Nov 1, 2017
    406
    38
    Hello @Alvin Maverick Cruz Check this from above
  8. Alvin Maverick Cruz
    Jan 11, 2018
    Hello Andy,
    Thanks for you prompt response!
    Will check it out then will give you response later thanks.
  9. Alvin Maverick Cruz
    Jan 11, 2018
    it seems i can push through..
    https://pixel-itsolutionsph.3cx.cn/webclient
    Logon to the Management Console
    Configure your system here:
    1. Go to pixel-itsolutionsph.3cx.cn
    2. Login using:
    a. Username admin
    b. Password xxxxx
    3. Public IP: xxxxxx
    This is not working
    #9 Alvin Maverick Cruz, Jan 11, 2018
  10. mariosM_3CX
    Nov 1, 2017
    406
    38
    Have you tried accessing the Management Console from a different connection?
    Not from a different PC on the same LAN as this will have the same Public IP address. You need to access from a different public ip. eg. from you smartphone using data network.
  11. voice11
    Jul 15, 2016
    48
    Hello Mario, I am having the same issue and yes I have tried both networks internal which is locked & another network which says "not accessible". Can you advise a fix please? Thank you.
  12. mariosM_3CX
    Nov 1, 2017
    406
    38
    Can you please tell me the exact message that you get when you are trying to access the Management Console?
    Also, please clarify if the PBX is installed on premise or on cloud and if is on windows or linux.
  13. voice11
    Jul 15, 2016
    48
    3CX Phone System
    And this is with webclient
    Welcome to the 3CX Web Client
    An IP has been blacklisted
  14. voice11
    Jul 15, 2016
    48
    Phones are working, I am just locked out of console. The only thing I have access to right now is command line. Is there any command I can putin in command line to unblock that IP.
  15. mariosM_3CX
    Nov 1, 2017
    406
    38
    You just need to access the management console from a different public IP that is not blacklisted by the PBX. Once you are in the Management Console, go from Dashboard to IP Blacklist and remove your IP from the list, or even whitelist it so you won't be locked out again in the future.
  16. voice11
    Jul 15, 2016
    48
    Yes.. I gathered it from conversation above. But this is my challenge that I can't access to console when I am outside of the local network. For example, I was never able to login to console when I am home. Is this what I would use when logging in remotely. But again it never worked.. i tried 5001 & 5000.
    https://voicencloud.3cx.ca:5001
  17. mariosM_3CX
    Nov 1, 2017
    406
    38
    Is the https port forwarded to the PBX? Because i cannot access it either.
  18. voice11
    Jul 15, 2016
    48
    huh...may be there lies the issue. I guess not... if it was something additional needed to be done, I didn't do it. Can you elaborate please? How do I do it? Do you do it on gateway or PBX?
  19. voice11
    Jul 15, 2016
    48
    Can anyone help?
  20. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Is this a cloud or local install?
