Log on/off at Queue via Manager - BUG?
Discussion in 'Windows' started by asegojv, Dec 21, 2015.
  1. asegojv
    Nov 23, 2015
    6
    if the Manager of a queue logs somebody off the queue via presence manager,
    the agent is no able to log in again via 3cx client (Q Button). And the status of the Q Button shows that the agent is still logged in!
    He has to use the presence manager to log on again.
    Is this a bug or a feature? :)
    Greetings!
  2. positron
    Jan 14, 2013
    74
    10
    Whether it is a bug or a feature may depend on your perspective, but I'll agree it can be confusing.
    The "Q" button controls login/logout status at the extension level, while changing queue login in the presence window controls login/logout at the queue level.
    If you have multiple call queues and are a member of more than one, you can use the presence view to selectively log in or out of specific queues. Using the "Q" button will then log you out or back in to only the queues you selected in the presence view.
    The "bug" would be if you log out of all queues in the presence view, the "Q" status for the phone will till show active, but since you're not logged in to any specific queues, your status doesn't change. And since the "Q" button only logs in or out for the previously selected queues, the "Q" button then does nothing until you log back in using the presence view.
    This can be a helpful process if you are a member of more than one queue, but usually do not participate in all of them, since the "Q" button will only act on the previously logged-in queues. It can be a problem if someone else (manager) is changing your queue login status via presence and you have no idea since you think you're logged in.
    I treat it as an education issue for any users/managers who intend to use the presence view to do queue logins to understand the impact. The biggest impact for me in managing and maintaining systems is that there is no view in 3CX Management to see which queues an extension is logged into, only the extension queue status. This can make for confusing troubleshooting when someone says they're logged out but the extension status shows IN and it can only be viewed or controlled through the 3CX Windows client, not via the 3CX Management web page.
  3. asegojv
    Nov 23, 2015
    6
    Many thanks!
    Of course it is both, a feature and a bug in my opinion.
    If you have more than one queue the behavior is right. But if you have only one queue or if the manager logs the agent off of every queue the agent should see this and should be able to log in again by clicking the "Q" button.
    Anyway I will not log off any agents until this "bug" is fixed or not.
    The agents have to learn to log off, when leaving the desk.
    Greetings!
  4. helpdesk_ict
    Nov 23, 2015
    This is definitely a feature, which we love because almost all our users are member of multiple queue`s.
    What is missing:
    - member rights to change the Q status (not the individual queue status) of colleagues (members of the same extention group).
    - member rights to change availability status of colleagues (members of the same extention group).
    This way, colleagues can correct eachothers failure to log off when leaving the desk.
