Log Out From Queue
Discussion in 'Call Flow Designer' started by ntnetzeband, Feb 5, 2018.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    Is there any way to use CFD for one person to be able to dial a queue number and it logs out or logs in everyone in a queue?
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    You can do it with a combination of a CFD application and external .Net Core components that execute methods of the Call Control API. It's certainly going to require C# and 3CX programming expertise. We can answer more technical questions here: https://www.VoIPTools.com
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
