- Joined
- Mar 22, 2015
- Messages
- 39
- Reaction score
- 6
Thank you for that explaination.Hi @viraltechnology,
You can't do that with the CFD. A CFD callflow is triggered with an inbound call, so it will not help you in this case.
You can use the 3CX Call Control API to do it (you need programming knowledge). Please note that this API runs on the 3CX server, so you need a process in the server, and another in the client (agent) machine. When you detect that the screen is locked in the app running in the client machine, you send the log-out request to your app in the server, which will use the Call Control API to log you out.
Kind regards.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
