LoggerNet Missing in System 12.5 SP2
Discussion in '3CX Phone System - General' started by darius, Jul 30, 2015.
  1. darius
    Jul 30, 2015
    From a fresh install of 12.5 and then followed by installation of SP2, the 3CX phone system basically is working.
    When we try to run the reports, error occurred.
    An exception occurred LoginForm Error. Could not load file or assembly "loggerNet, Version=12.0.0.0, Culture=....."
    Found that LoggerNet v4.0_14.0.0.1 is installed under the Microsoft.Net\assembly\GAC_MSIL directory.
    Anyone has idea on how to add back LoggerNet 12.0.0.0 to the system ?
    Thanks.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Please open a ticket on our support portal so that this can be investigated further.
  3. mcesaric
    Aug 3, 2015
    I have the same issue with exception that my phone system was upgraded from 12.5 SP1 > 12.5 SP2. Additionally, management console and wallboard are working, phone system in general is working, but reports and webrtc don't.
    How to open support ticket? I have license with maintenance valid until next year. It isn't an option to buy a support package since I don't think it is a configuration error and because everything worked just fine before the upgrade.
    Thankyou.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    In that case please contact your reseller so that he opens the ticket on your behalf.
  5. kbrv
    May 15, 2013
    22
    Hi, I had the same issue and support recommended the following procedure.
    In the management console.
    Go to Settings > Advanced > Custom parameters and search for VERSION
    Change the version to 12.5.40178.1005
    Press Apply
    Go to Updates > 3CX Service pack updates
    Apply Sp1 and Sp2 again.
    This procedure will solve your problem.
