Login Access Denied
Discussion in '3CX Phone System - General' started by markf100, Jun 16, 2017.
  1. markf100
    Jun 11, 2017
    15
    New system, local server, in the process of setting up and then was dropped back to a login screen and cannot login - is there low level access or a way to perhaps reset?
    The message is " Login access denied. Too many incorrect login attempts. Try later or contact the Administrator."
    Thank you
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,349
    274
    Hello @markf100
    That means that you have been blacklisted for too many incorrect login attempts. Your ip will be removed from the blacklist after 30 minutes or you can try logging in from a different IP and manually whitelist your IP
