login by web
Discussion in '3CX Phone System - General' started by spring, Feb 15, 2016.
  1. spring
    Nov 20, 2014
    53
    Hi, In version 14SP2 can i login to my 3cx by web interface using server ip?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    You still can log into the Management Console if you have a Single-Instance installation, if you have a Virtual PBX (Multi-Instance) installation though you will not be able to, you must use each instances FQDN.
  3. spring
    Nov 20, 2014
    53
    Thanks you for your answer. My 3cx server use single instance but i can't login to web interface by ip address.
  4. NickD_3CX
    Jun 2, 2014
    1,283
    68
    Actually my previous response was only half true. I was since told that Abyss will allow it but IIS will not.
  5. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    NickD,
    Probably a separate post but why did 3CX decide to only allow port 80 with IIS with v14+?
    thanks
  6. NickD_3CX
    Jun 2, 2014
    1,283
    68
    Not too sure to be honest, it might have something to do though with the fact that the Single-Instance installation is now essentially a Virtual PBX installation just hard-coded to use 1 instance and because this is a requirement for the Virtual PBX it remains the same for the Single Instance as well.
    With the Abyss Web Server option though the option is still there and due to some performance fixes for Abyss in V14, it should cope pretty well for systems up to 32 Sim Calls and using 100-120 extensions.
