login to individual queues
Discussion in '3CX Phone System - General' started by jamesdawson, Feb 5, 2014.
  1. jamesdawson
    Jan 30, 2014
    21
    Hi, is there a way for an extension to be logged in/out of individual queues?
    ie if an extension is a member of 3 queues, and you only want them logged into the first queue, is this possible?
    thanks
    james
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You could add / remove them as a member from the management console.. not ideal but just throwing that out there.
  3. jjwerkman
    Sep 25, 2012
    42
    It is possible: http://www.3cx.com/blog/extension-user-manual/manage-your-queues/
