Logo 3Cx webclient
Discussion in '3CX Phone System - General' started by Jor3cx, Feb 22, 2018.
  1. Jor3cx
    Oct 26, 2017
    15
    Goodmorning,
    I would like to change the small logo of 3cx to the logo of my client in the web client of 3CX. In which folder of the 3CX do I have to change the logo to realize this?
    Thanx.
    grz Jor3cx
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,441
    189
    For the client for Windows on the client itself simply go to:
    Settings >> Themes >> Set custom image
    You will need to import from your desktop an image which is 270 x 80 pixels.
  3. Jor3cx
    Oct 26, 2017
    15
    sorry I do not understand you right away.
    I mean the logo above the login screen of the web client and the logo at the top left of the web client itself.
    If i go to the webclient to settings/themes, i cant import a logo.
    I think it is possible to place the logo in a folder of 3cx and that every web client who logs in immediately sees the company's log at login and in the web client itself
    if, for example, you would like to change the device logo, do so in the folder
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/xxxxxxxxxx/logo
    AH2 likes this.
  4. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    Yes that would be the way to go, since 3cx does not support rebranding they probably will not offer support for this, only letting you know you can ADD your logo to the Windows client using the settings they gave you, this will ONLY change the Windows Client that you configure the image to.
    Cheers.
    Jor3cx likes this.
  5. Jor3cx
    Oct 26, 2017
    15
    Thanx for youre reply, i will set cutom image in the client.
