Logo stretches in Softphone
Discussion in 'Ideas' started by craigreilly, May 18, 2017.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    I set my logo per recommendation of 270x80 in the software (on Mac)... however, if the user makes the Dialog box WIDER - then the logo stretches.
    I think the logo should not stretch and keep proportions proper.
    AGidi likes this.
