Long call 2h23m is shown active but it's not...
Discussion in '3CX Phone System - General' started by Ben C, Jul 13, 2016.
  1. Ben C
    Oct 14, 2014
    71
    I saw on the Switchboard a call with an abnormal duration, over 2 hours (see attached).
    The caller (ext 123) hung up when the voice mail of ext 141 kicked in. The call is disconnected but it's shown as active one and still counting...
    The 'Activity Log' for this call:
    13-Jul-2016 13:26:19.333 [CM503007]: Call(C:154): Extn:123 has joined, contact <sip:123@10.2.7.77:5060>
    13-Jul-2016 13:26:19.331 L:154.4[VMail] has joined to L:154.1[Extn]
    13-Jul-2016 13:26:19.181 [CM503025]: Call(C:154): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:5483;rinstance=9edfd8636ea7261a] for L:154.1[Extn]
    13-Jul-2016 13:26:19.178 L:154.1[Extn] forwards call from Extn:141 to VMail:999 based on rule Fwd[Available/NoAnsw]
    13-Jul-2016 13:26:19.178 L:154.1[Extn] failed to reach Extn:141, reason No Answer
    13-Jul-2016 13:25:59.145 [CM503025]: Call(C:154): Calling T:Extn:141@[Dev:sip:141@10.2.7.97:5060,Dev:sip:141@10.2.7.35:56393;rinstance=1-401a82ff73b140c8b514738fa0b709cd;ob] for L:154.1[Extn]
    13-Jul-2016 13:25:59.143 [CM503025]: Call(C:154): Calling T:Extn:141@[Dev:sip:141@10.2.7.97:5060,Dev:sip:141@10.2.7.35:56393;rinstance=1-401a82ff73b140c8b514738fa0b709cd;ob] for L:154.1[Extn]
    13-Jul-2016 13:25:59.123 [CM503027]: Call(C:154): From: Extn:123 ("Dean McCarroll" <sip:123@phone.ims.ca:5060>) to T:Extn:141@[Dev:sip:141@10.2.7.97:5060,Dev:sip:141@10.2.7.35:56393;rinstance=1-401a82ff73b140c8b514738fa0b709cd;ob]
    13-Jul-2016 13:25:59.123 [CM503004]: Call(C:154): Route 1: from L:154.1[Extn] to T:Extn:141@[Dev:sip:141@10.2.7.97:5060,Dev:sip:141@10.2.7.35:56393;rinstance=1-401a82ff73b140c8b514738fa0b709cd;ob]
    13-Jul-2016 13:25:59.122 [CM503001]: Call(C:154): Incoming call from Extn:123 to <sip:141@phone.ims.ca:5060>
    The 'BYE' command is missing..
    A few minutes later this extension made another call to different extension, this time the BYE command was there:
    13-Jul-2016 13:45:25.454 Leg L:171.1[Extn:123] is terminated: Cause: BYE from 10.2.7.77:5060
    13-Jul-2016 13:45:19.237 [CM503007]: Call(C:171): Extn:123 has joined, contact <sip:123@10.2.7.77:5060>
    13-Jul-2016 13:45:19.236 L:171.3[VMail] has joined to L:171.1[Extn]
    13-Jul-2016 13:45:19.095 [CM503025]: Call(C:171): Calling T:VMail:999@[Dev:sip:999@127.0.0.1:5483;rinstance=9edfd8636ea7261a] for L:171.1[Extn]
    13-Jul-2016 13:45:19.092 L:171.1[Extn] forwards call from Extn:147 to VMail:999 based on rule Fwd[Available/NoAnsw]
    13-Jul-2016 13:45:19.092 L:171.1[Extn] failed to reach Extn:147, reason No Answer
    13-Jul-2016 13:44:59.082 [CM503025]: Call(C:171): Calling T:Extn:147@[Dev:sip:147@10.2.7.183:5060] for L:171.1[Extn]
    13-Jul-2016 13:44:59.033 [CM503027]: Call(C:171): From: Extn:123 ("Dean " <sip:123@phone.ims.ca:5060>) to T:Extn:147@[Dev:sip:147@10.2.7.183:5060]
    13-Jul-2016 13:44:59.033 [CM503004]: Call(C:171): Route 1: from L:171.1[Extn] to T:Extn:147@[Dev:sip:147@10.2.7.183:5060]
    13-Jul-2016 13:44:59.032 [CM503001]: Call(C:171): Incoming call from Extn:123 to <sip:147@phone.ims.ca:5060>
    I have seen this happen 3 times with the same extension (twice with the VM of the same extension and once calling external number).
    Any idea what could cause this?
    Thank you
