- Joined
- Feb 28, 2011
- Messages
- 4
- Reaction score
- 0
to anyone's knowledge, is there a time limit on a connection to a 3cx softphone (windows) of approximately THREE hours?
many thanks
many thanks
abc123 said:not if there is any data going through it. But your PC may go to sleep if there is no key or mouse functions in that time.
Who is cutting you off? Sometimes a provider or even CLECs will cut a call after a long duration, especially if long periods of silence are detected.
mfm said:Hi,
yes there is a limit on the phone conversation length setup. this is a sort of safety net for calls that might not have ended properly. But having said that why would you want a 3 hour phone call.
As to your probable next question no this cannot be changed.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
