Looking for a ready made Webclient Windows app
Discussion in 'CRM / Helpdesk / App Integration' started by Cees Rijken, Apr 7, 2017.
  1. Cees Rijken
    Apr 7, 2017
    Hi there,
    I am an absolute newbie in the 3CX area, so bear with me...
    I am looking for a way that the 3CX Softphone for Windows identifies the incoming number and fires an URL, so basically how the SugarCRM integration works, except... my company does not work with SugarCRM, but with a custom built online CRM.
    I've been browsing through the online documentation and what I supposedly need it the 3CX VAD, right?
    But before I start diving in, I was wondering if there was already someone out there having developped the same thing I want.
    Mind you: this does not have to be free. I am willing to pay a reasonable price for saving me going through the VAD manual and/or refreshing my .NET skills...
    If only I could define my own keyboard shortcut in the Windows client....
    Cheers,
    Cees
  2. Cees Rijken
    Apr 7, 2017
    Mmmm, I just noticed that under Advanced Settings --> Behaviour --> External Application, I can launch another client application....
    I will check that out!
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,236
    95
    Hi @Cees Rijken,
    You can use the Launch External Application from 3CXPhone, or you can create a plug-in for 3CXPhone. All the integrations we provide, for example SugarCRM, are plug-ins for 3CXPhone. You can easily create a new plug-in to integrate with your CRM system using the Visual Studio template we provide. Please check the documentation here:
    https://www.3cx.com/blog/releases/crm-integration-diy/
    Kind regards.
  4. bigdessert
    Apr 3, 2017
    18
    I just set this up the other day as we use a custom crm as well. Fairly easy to get it working but you must know some c# programming.
  5. BobMinteer
    Oct 11, 2016
    10
    5
    My company also uses a custom CRM which I developed on the FileMaker platform. I use the 3CX Client for Windows' ability to launch an external program to "fire" a URL that points at the CRM client (FileMaker Pro) which calls a script and passes the caller ID and name info.
    To do this, I set the Internet Explorer as the external program to launch and pass the parameters along as:
    fmp://*/JobManager?script=external_view&$viewphone=%CallerNumber%&$callername=%CallerDisplayName%
    where:
    fmp:// is the protocol for talking to my solution
    */JobManager is the CRM Client name running on the local machine (desktop or terminal server)
    ...and the rest are the parameters that I want IExplorer to pass along to my CRM for processing
    In my case, this provides my users with screen pops on every incoming call.
    Because FileMaker handles calls from external sources as such, I didn't even have to create a plugin to provide all of the functionality that I needed to support my users.
    AH2 likes this.
