Looking for an affordable sip trunking service
Discussion in '3CX Phone System - General' started by MichaelD, Mar 2, 2017.
  1. MichaelD
    Mar 27, 2010
    36
    Hello all,
    I am looking for a secure, affordable, reliable sip trunking service for 3CX for our small office. Preferably one where I can get static phone numbers that will never change.
    Does such a thing exist?
    Thanks,
    md
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
  3. leejor
    10,360
    226
    Never, is a long time. Keep in mind that any number that is assigned by a provider, may be lost if that company ever goes out of business. In many cases, a number will be brought with, and ported to a provider. You may have fewer issues taking that (type of) number with you if you choose to move to another provider, for what ever reason.
    If long term retention of a number is critical, then ask (and perhaps get a response in writing) "what will happen to my number if...?"
    #3 leejor, Mar 2, 2017
  4. daktur
    daktur New Member
    Oct 15, 2015
    225
    6
    Hi All,
    I will definitely recommend broadvoice / phone power. They have the best cost benefit and the quality is excellent. I have been using them for more then 10 years now.
    Hope you enjoy as well.
  5. gschmidt
    Jul 16, 2017
    5
    I'm almost 4 weeks new to 3CX and seem to be having trouble with inbound calls on broadvoice/phone power.
    Would someone be kind enough to show me the sip configuration?
  6. daktur
    daktur New Member
    Oct 15, 2015
    225
    6
    @gschmidt what kind of problems? They are supported by 3cx and you should have no problems.
    Please describe your issue in order to get better and more specific help.
  7. gschmidt
    Jul 16, 2017
    5
    From what I can tell, the inbound calls never hit my server.
    The image below shows my basic config for the trunk.
    Outbound calls work, just not inbound.
  8. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    733
    112
    Generally if calls aren't hitting the trunk/PBX it's not a trunk/3CX problem but a firewall problem. Does your install pass the firewall test?
  9. gschmidt
    Jul 16, 2017
    5
    I appreciate your response cobaltit.
    I've checked and double-checked the firewall. Passed each time.
    Even went so far as to order a trunk from Vitelity, which is working great for outbound
    and inbound calls.
  10. AlexDBarrett
    Jan 25, 2011
    71
    9
    UK provider which is low cost is VoIPFon. Not an approved provider however it works.
