looking for free softphone with WLM
Discussion in 'Windows' started by andersonshen, Apr 23, 2008.
  1. andersonshen
    Mar 31, 2008
    Dear All,
    I looking for free softphone and integrate Windows Live Messenger, like eyeball messenger.
    (It can login WLM and myselfe SIP server)
    Can you give me advise ?
    Thanks a lot !!
  2. mutti_wilson
    May 2, 2008
    53
    Check out http://www.fring.com
    It should do what you are looking for. It's free and also has a Windows Mobile compatible version.
  3. mutti_wilson
    May 2, 2008
    53
