Loop component
Discussion in 'CRM / Helpdesk / App Integration' started by Michaelhal, Apr 20, 2012.
  1. Michaelhal
    Nov 18, 2011
    8
    Hi ,
    I am trying to create a record component where the user records audio then playback that audio , after this i got a user input component and a conditional component where 1 = continue and 2 = re-record. this all is packaged in a loopcomponent.
    now i have created a project variable $Callflow.HasToRecord and set it to true,
    the Loop component condition = HastoRecord
    When the user selects 2 to re-record i assign an variable assignment where i have set HasToRecord to false.
    when i select 1 to continue or 2 to re-record it just keep looping me arround
    i also tryed setting the loop condition to equal HasToRecord.true
    But still it loops me arround
    3cxIVRserverlog shows me : error id 301 on my loop component
    what am i doing wrong here ?
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Can you post your project so I take a look at it? Please, remove credentials if you have them into the project. Or send me a private message with it so I take a look. It will be much easier that way.
    Thanks,
  3. Michaelhal
    Nov 18, 2011
    8
    Nevermind i created an new project with a loop in it and it worked on the second try i must have done something wrong the first time , ahh well i got it working now no need to waste your time on my project.
    You can delete this topic if you want
  4. VAD_Support
    Aug 6, 2009
    690
    OK, no problem. thanks.
