loopback gateway caller id
Discussion in '3CX Phone System - General' started by pipex, Aug 1, 2013.
  1. pipex
    Jul 25, 2013
    16
    hello,
    i have a 3cx v.11 enterprise and i created the canonical 100 as main operator extension but people requested me the possibility to call the extension 100 with a single number (9). so i created a loopback sip gateway that seems working. anyway when people are calling using the number 9, on the operator display i see the call from 9 to 9 .
    how i can show the correct extension that is calling ?
    thanks in advance.
    regards
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Go to the extension 100 page and then to the other tab and look for SIP ID, then enter the desired number "9" and apply and save. You will now be able to dial extension 100 using only the 9 key.
  3. pipex
    Jul 25, 2013
    16
    thanks for quick reply, i'll try tomorrow.
  4. pipex
    Jul 25, 2013
    16
    works perfectly! thanks
