loosing the "Extension is external" status from co
Discussion in '3CX Phone System - General' started by silentfun, Jul 7, 2007.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    loosing the "Extension is external" status from configuration
    ext 100 loosing ist ext 200 not but when i build a nex 201 extension it loose the status too.
    any suggestion ?
  2. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    you mean you tick the box: this extension is external. and go back its unchecked?
    You aresure you pressed ok in the bottom afther you made the chance to save it?
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    :) yes i am shure. this are basics i check.
    but it is not unchecked after some seconds it can take up to hours.
    this came first after update
    if i am the only one i will try to reinstall but atm i am ill and have much work waiting
    andy
  4. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    im not using that setting (my softphone at home works perfectly without it, only hardware phones require it) so im not sure.
    ITFarmer? you had this issue?
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    yes i use hardware phones
  6. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i did some additional testing.
    i hav added a new extension with the same value (only other extension) like that one that loose the "external" mark. and it is also loosing the mark.
    but now the old unused extension don
  7. Anonymous
    Anonymous Guest
    That is weird, I cannot replicate it here.
    Bounce it up to 3cx support, they should be able to replicate it in the lab. If so it is a bug, if not well.......... it could mean that the aliens have landed in germany. (of all countries in the world, why germany :lol: )
    I have no idea why this is happening.
  8. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    Extension is External - Settings saved incorrectly
    I tried to replicate this problem however it obeys perfectly. I tried with a number of different and random extensions too giving special attention to 200 and 201. Each time the setting was observed. Did you try removing the extensions and recreating them again from scratch?? Thanks
  9. silentfun
    silentfun Member
    Dec 11, 2006
    364
    no i have not build up all from scratch because it have taken some time to get all like i want everything else is ok . but i made a new extension and it did the same then the old one before. but since the old one is not longer registered with a phone it don
  10. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
  11. silentfun
    silentfun Member
    Dec 11, 2006
    364
    ok after a night here - the setting "external" escaped again.
    so it wasn
  12. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    Hi silent fun
    Just to make sure that I understood correctly. Example - you have created 2 EXT; ext 100 and another 101. You set these 2 extensions as ext are external in the 3CX config. Correct??? You make a couple of calls - in this case you called 999, and when you go back in the extension's settings page, you realise that the checkbox showing that the extension is external is not checked anymore. Is this the problem? You also gave an indication that this does not happen all the time - it happens very rarely - What do you think generates this? and am I on the right track? And this has happened to you when the phonesa are registered correct?? An unregistered phone keeps the correct provided settings.
    I am checking on it ok.
  13. silentfun
    silentfun Member
    Dec 11, 2006
    364
    yes you are on the right way. and yes a unregistered extension hold the extern option in place.
    my config is neare your example
    ext 100 me
    ext 200 my partner <- this is the buggy one
    ext 201 at replacement for ext 200 same then before
    my own extension i don
  14. SY
    3CX Support
    Jan 26, 2007
    1,825
  15. silentfun
    silentfun Member
    Dec 11, 2006
    364
    ok i have solved the problem.
    this is invincible. the computer of my partner use still the call assistant of the last build and if he logs in he removes the extern option - i suggest it use the same variable for a other thing.
    i already use the new call assistant since update.
    this was realy hard to catch
    the problem happened only when my partner reboot the workstation (from time to time)
