Losing connection to VOIP provider
Discussion in '3CX Phone System - General' started by 3397premier, Apr 25, 2012.
  1. 3397premier
    Apr 2, 2012
    43
    Just about every day our phones go down around the same time - ~9:30AM CST. They are down until I re-register the connection to our VOIP provider. This only affects outgoing calls not incoming.
    We get this message first:
    Trunk L:10001(VOIP Provider Name) has changed status to unregistered. This means that no more calls will pass via this trunk. Please check your network connection and the voip provider or other SIP PBX
    Then we get this one next:
    Registration at VOIP Provider has failed. Destination (sip:Voip Provider@192.168.1.1:5060) is not reachable, DNS error resolving FQDN, or service is not available.
    The next comes this error:
    Device ####### dialed on (AnyLine@Voip Provider) had no available outgoing trunk(s) for Call(from "Username"<sip:4042@172.17.0.15>;tag=7AC6A33C-E5AFD8EF to #######)
    We do not use stun, just a specified IP. Our setup is a Dell R510 server with 3CX Enterprise, Cisco ASA 5505 router, Cisco SG300 switches and our internet is cable with 100 down and 20 up. Any assistance would be much appreciated.
    Thank you,
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Do you have a system update or backup or anything on that server normally scheduled at the time the line become unregistered?
  3. 3397premier
    Apr 2, 2012
    43
    No, we don't
  4. jeffreicher
    Sep 22, 2012
    I am having the same situation. Have you been able to solve get to the root cause and/or a solution? thanks, Jeff
  5. jpillow
    Jun 20, 2011
    1,342
    Who is your service provider? possibly you both have the same provider and that may be why youre experiencing these issues.
  6. Eric
    Sep 25, 2012
    Dear friends search on google, there are so many sites that provide information about loosing connection to VOIP .I am sure you'll definitely get some help from there.
