Lost Account
Discussion in 'Windows' started by spring, Feb 5, 2016.
  1. spring
    Nov 20, 2014
    53
    Some of my 3CX phone for windows client account (Version 14) lost after restart PC and i need to send welcome email again or create account again. this happen with 3 or 4 clients already. Any advice?
  2. Charles_3CX
    Charles_3CX New Member
    3CX Support
    Jul 6, 2015
    114
    HI There
    Since version V14 SP1 3CXPhone clients ONLY save the current running config when "Exit Client" is used at least once before
    shutting down the PC. Once Exited the once before shutting down the phone will save:
    Accounts
    Audio / Video settings
    Layout and positioning
    To exit 3CXPhone, Click 'Settings' > ' Exit Client' before shutting down the computer. (Only needs to be done one time)
  3. spring
    Nov 20, 2014
    53
    Thanks you for your answer.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    This seems kind of odd to me.
    Shouldn't logging off your computer softly shut down any running apps - ie: 3cx Phone - and save the settings.
    Why should I have to manually shut down the app to save settings?
    I've been chasing this one. Glad I found this post... and this one: version-14-loses-config-on-every-reboot-44108.html
  5. cfive
    cfive Member
    Aug 20, 2009
    284
    I think it's fixed with SP3.
