Lost all my contacts
Discussion in '3CX Phone System - General' started by JChill, May 5, 2017.
  1. JChill
    Apr 8, 2017
    19
    Is there a cause why I could loose al my contacts ?
    Also, why contacts entered from a client remains on the client and are not visible to the other clients ?
    Regards,
    Giuseppe Chillemi
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @JChill,
    What version is your PBX? Please let us know so we can figure out what could cause the deletion of your contacts.
    Also, for your second question, the parameter "Can manage the company phonebook" should be enabled from Extensions > double click on preferred extension > Rights. This should be done on all the extensions that have the need to customize the company phonebook.
  3. JChill
    Apr 8, 2017
    19
    Version 15.0.59381.0 here (8 sim. calls)
    I have changed some internals to allow them to modify company contacts but the remaining had already this settings.
    Actually the company conctact list has only 1 contact while the other seems to have returnend to populate the windows client. For some Reason the windows client
    1) Has lost contact but has then regained them
    2) Conctacts are not bein transfered to the main contact list
    Regards
    JChill
