Lost Call in Queue
Discussion in '3CX Phone System - General' started by hitmanist, May 29, 2012.
  1. hitmanist
    May 29, 2012
    for every call there is a warning ( lost call in queue ) in Server Event Log
    15:42:12.783 [CM503023]: Call(72): Call recording is stopped, audio file: C:\ProgramData\3CX\Data\Recordings\108\
    15:38:56.117 [CM503008]: Call(73): Call is terminated
    15:38:56.114 [CM503022]: Call(72): Call recording is started, audio file: C:\ProgramData\3CX\Data\Recordings\108\
    15:38:56.107 [CM503023]: Call(73): Call recording is stopped, audio file: C:\ProgramData\3CX\Data\Recordings\108\
    15:38:56.104 [CM505002]: Gateway:[MP-118] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-/v.5.80A.023.006] PBX contact: [sip:10006@192.168.2.89:5060]
    15:38:55.898 [CM503007]: Call(73): Device joined: sip:108@192.168.2.191:5070;rinstance=f1a9fdcab7180b43
    15:38:55.896 [CM503007]: Call(73): Device joined: sip:802@127.0.0.1:5488
    15:38:55.894 [CM503022]: Call(73): Call recording is started, audio file: C:\ProgramData\3CX\Data\Recordings\108\
    15:38:48.509 [CM503025]: Call(73): Calling Ext:Ext.108@[Dev:sip:108@192.168.2.191:5070;rinstance=f1a9fdcab7180b43]
    15:38:48.464 [CM503004]: Call(73): Route 1: Ext:Ext.108@[Dev:sip:108@192.168.2.191:5070;rinstance=f1a9fdcab7180b43]
    15:38:48.459 [CM503001]: Call(73): Incoming call from Ext.802 to <sip:108@127.0.0.1:5060;nofwd=1;tag3cx=43-DKKFIOSDYN>
    15:38:47.729 [CM503007]: Call(72): Device joined: sip:802@127.0.0.1:5488
    15:38:47.559 [CM503025]: Call(72): Calling Ext:Ext.802@[Dev:sip:802@127.0.0.1:5488]
    15:38:47.506 [CM503004]: Call(72): Route 1: Ext:Ext.802@[Dev:sip:802@127.0.0.1:5488]
    15:38:47.505 [CM505002]: Gateway:[MP-118] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-/v.5.80A.023.006] PBX contact: [sip:10006@192.168.2.89:5060]
    15:38:30.600 [CM503007]: Call(72): Device joined: sip:805@127.0.0.1:40600;rinstance=48a72b49ff6ecfcf
    15:38:30.599 [CM503007]: Call(72): Device joined: sip:10006@192.168.2.99:5060
    15:38:30.435 [CM503025]: Call(72): Calling Ext:Ext.805@[Dev:sip:805@127.0.0.1:40600;rinstance=48a72b49ff6ecfcf]
    15:38:30.391 [CM503004]: Call(72): Route 1: Ext:Ext.805@[Dev:sip:805@127.0.0.1:40600;rinstance=48a72b49ff6ecfcf]
    15:38:30.389 [CM505002]: Gateway:[MP-118] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Audiocodes-Sip-Gateway-/v.5.80A.023.006] PBX contact: [sip:10006@192.168.2.89:5060]
    15:38:30.388 [CM503001]: Call(72): Incoming call from 03122569988@(Ln.10006@MP-118) to <sip:805@192.168.3.2:5060>
    15:38:30.382 [CM503012]: Inbound office hours rule (unnamed) for 10006 forwards to DN:805
    805 ivr
    802 queue manager
    108 extension
    as you see while calling 72 is goin on, a call named 73 is appear.
    and in call records 73's size 1kb.
    and 73 seen as lost call in queue.
    phone system 10, win 7 32 bit.
