Credentials don't match, check that authorization-ID and password match the ones in extension settings
to be honest, I don't believe that it worked with SP4.joseh said:yes, i did check and triple check them. they were working before i install the sp5. with the sp4 were working.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
