Lost voice mail messages
Discussion in '3CX Phone System - General' started by Jonners59, Nov 1, 2010.
  1. Jonners59
    Jonners59 New Member
    Apr 21, 2009
    129
    I have been using 3CX on Vista for 2 years now. I recently upgraded my Server to run Ubuntu 10.4 (Linux). I installed Sun's VirtualBox and set up a virtual machine within which I run Windows 7. I then installed the latest version of 3CX in this virtual machine/Windows7 environment and used the back up config to setup the new 3CX system. It works great, but for one thing.... When voice mail messages are left by callers, it does not seem to exist. The message is not in the users account, and is not sent by eMail as a wav file as it used to.
    Where have they all gone?
  2. Jonners59
    Apr 21, 2009
    129
    Any help please???????
    Code:
    19:39:47.707
    Currently active calls - 1: [24]
    19:39:17.691
    19:39:05.906
    Session 52115 of leg C:24.1 is confirmed
    19:39:05.617
    [CM503007]: Call(24): Device joined: sip:844231085@voiptalk.org:5060
    19:39:05.577
    [CM503007]: Call(24): Device joined: sip:100@192.168.1.91:5060
    19:39:05.568
    [MS210001] C:24.2:Answer received. RTP connection[unsecure]: 77.240.48.210:41008(41009)
    19:39:05.563
    Remote SDP is set for legC:24.2
    19:38:50.705
    [MS210003] C:24.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.1.51:7100(7101)
    19:38:50.700
    19:38:50.694
    19:38:50.688
    [CM505003]: Provider:[VoIPTalk] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:844231085@93.97.190.219:5060]
    19:38:50.688
    [CM503002]: Call(24): Alerting sip:844231085@voiptalk.org:5060
    19:38:50.089
    [CM503025]: Call(24): Calling VoIPline:02086603837@(Ln.10005@VoIPTalk)@[Dev:sip:844231085@voiptalk.org:5060]
    19:38:50.073
    [MS210002] C:24.2:Offer provided. Connection(transcoding mode): 93.97.190.219:9016(9017)
    19:38:49.917
    [CM503004]: Call(24): Route 3: PSTNline:99102086603837@(Ln.10001@GWX 4104)@[Dev:sip:10001@192.168.1.95:5060;transport=udp,Dev:sip:10002@192.168.1.95:5062;transport=udp,Dev:sip:10003@192.168.1.95:5064;transport=udp,Dev:sip:10004@192.168.1.95:5066;transport=udp]
    19:38:49.915
    [CM503004]: Call(24): Route 2: VoIPline:02086603837@(Ln.10005@VoIPTalk)@[Dev:sip:844231085@voiptalk.org:5060]
    19:38:49.915
    [CM503004]: Call(24): Route 1: VoIPline:02086603837@(Ln.10005@VoIPTalk)@[Dev:sip:844231085@voiptalk.org:5060]
    19:38:49.912
    [CM503010]: Making route(s) to <sip:02086603837@192.168.1.51;user=phone>
    19:38:49.912
    [MS210000] C:24.1:Offer received. RTP connection: 192.168.1.91:5008(5009)
    19:38:49.906
    Remote SDP is set for legC:24.1
    19:38:49.905
    [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [S685IP022230000000] PBX contact: [sip:100@192.168.1.51:5060]
    19:38:49.833
    [CM503001]: Call(24): Incoming call from Ext.100 to <sip:02086603837@192.168.1.51;user=phone>
    19:38:49.809
    [CM500002]: Info on incoming INVITE:
    INVITE sip:02086603837@192.168.1.51;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.91:5060;branch=z9hG4bK3b80abae70d6bda82a8c8650573daf4a;rport=5060
    Max-Forwards: 70
    Contact: <sip:100@192.168.1.91:5060>
    To: <sip:02086603837@192.168.1.51;user=phone>
    Call-ID: 1852787869@192_168_1_91
    CSeq: 3 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:02086603837@192.168.1.51;user=phone",nonce="414d535c02e24b4959:e52e848c8cefc07f76762b334dd416c7",response="1fd564b0b35f1a95ae5d718c0eb6ba98"
    Supported: replaces
    User-Agent: S685IP022230000000
    Allow-Events: message-summary, refer, talk
    Content-Length: 0
    19:38:47.613
    Currently active calls [none]
    19:38:17.373
    19:37:47.306
    19:37:17.221
    19:36:47.120
    19:36:16.958
    19:36:09.354
    [CM503008]: Call(23): Call is terminated
    19:35:46.845
    Currently active calls - 1: [23]
    19:35:39.597
    [MS210005] C:23.5:Answer provided. Connection(proxy mode):127.0.0.1:7098(7099)
    19:35:39.588
    [MS210001] C:23.1:Answer received. RTP connection[unsecure]: 192.168.1.95:5020(5021)
    19:35:39.583
    Remote SDP is set for legC:23.1
    19:35:39.515
    [CM503007]: Call(23): Device joined: sip:900@127.0.0.1:40600;rinstance=9540f42d92b18ac3
    19:35:39.508
    [MS210004] C:23.1:Offer provided. Connection(proxy mode): 192.168.1.51:7092(7093)
    19:35:39.500
    [MS210000] C:23.5:Offer received. RTP connection: 127.0.0.1:40628(40629)
    19:35:39.495
    Remote SDP is set for legC:23.5
    19:35:39.492
    [CM505001]: Ext.900: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:900@127.0.0.1:5060]
    19:35:39.492
    [CM503002]: Call(23): Alerting sip:900@127.0.0.1:40600;rinstance=9540f42d92b18ac3
    19:35:39.298
    [CM503025]: Call(23): Calling Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=9540f42d92b18ac3]
    19:35:39.211
    [CM503005]: Call(23): Forwarding: Ext:Ext.900@[Dev:sip:900@127.0.0.1:40600;rinstance=9540f42d92b18ac3]
    19:35:19.691
    19:35:19.691
    [CM503002]: Call(23): Alerting sip:844231085@voiptalk.org:5060
    19:35:19.093
    [CM503025]: Call(23): Calling HuntGrp809:10607770740133@(Ln.10005@VoIPTalk)@[Dev:sip:844231085@voiptalk.org:5060]
    19:35:19.080
    [MS210002] C:23.4:Offer provided. Connection(transcoding mode): 93.97.190.219:9014(9015)
    19:35:18.906
    [CM503004]: Call(23): Route 1: HuntGrp809:10607770740133@(Ln.10005@VoIPTalk)@[Dev:sip:844231085@voiptalk.org:5060]
    19:35:18.874
    [CM503010]: Making route(s) to <sip:809@127.0.0.1:5060>
    19:35:18.865
    Refer: from=<sip:806@127.0.0.1:5060>;tag=770ca042; to=":Home"<sip:unknown@127.0.0.1:5060>;tag=4c49e96a; RefTo=<sip:809@127.0.0.1:5060>
    19:35:18.655
    [MS210003] C:23.3:Answer provided. Connection(transcoding mode[unsecure]):127.0.0.1:7096(7097)
    19:35:18.648
    19:35:18.641
    19:35:18.534
    [MS210002] C:23.1:Offer provided. Connection(transcoding mode): 192.168.1.51:7092(7093)
    19:35:18.530
    [MS210000] C:23.3:Offer received. RTP connection: 127.0.0.1:40626(40627)
    19:35:18.515
    Remote SDP is set for legC:23.3
    19:35:16.804
    19:34:50.687
    Session 52057 of leg C:23.1 is confirmed
    19:34:50.634
    [CM503007]: Call(23): Device joined: sip:806@127.0.0.1:40600;rinstance=cb269b8137a0818e
    19:34:50.601
    [CM503007]: Call(23): Device joined: sip:10003@192.168.1.95:5064;transport=udp
    19:34:50.595
    [MS210005] C:23.1:Answer provided. Connection(proxy mode):192.168.1.51:7092(7093)
    19:34:50.581
    [MS210001] C:23.3:Answer received. RTP connection[unsecure]: 127.0.0.1:40626(40627)
    19:34:50.574
    19:34:50.572
    [CM505001]: Ext.806: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:806@127.0.0.1:5060]
    19:34:50.572
    [CM503002]: Call(23): Alerting sip:806@127.0.0.1:40600;rinstance=cb269b8137a0818e
    19:34:50.396
    [CM503003]: Call(23): Call to sip:110@192.168.1.51 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.91:5060
    19:34:50.285
    [CM503025]: Call(23): Calling Ext:Ext.806@[Dev:sip:806@127.0.0.1:40600;rinstance=cb269b8137a0818e]
    19:34:50.281
    [MS210004] C:23.3:Offer provided. Connection(proxy mode): 127.0.0.1:7096(7097)
    19:34:50.188
    [CM503005]: Call(23): Forwarding: Ext:Ext.806@[Dev:sip:806@127.0.0.1:40600;rinstance=cb269b8137a0818e]
    19:34:46.748
    19:34:31.828
    [CM505001]: Ext.110: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [S685IP022230000000] PBX contact: [sip:110@192.168.1.51:5060]
    19:34:31.828
    [CM503002]: Call(23): Alerting sip:110@192.168.1.91:5060
    19:34:30.136
    [CM503025]: Call(23): Calling RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.91:5060]
    19:34:30.131
    [MS210006] C:23.2:Offer provided. Connection(by pass mode): 192.168.1.95:5020(5021)
    19:34:30.103
    [CM503004]: Call(23): Route 1: RingAll801:110Ext.110105Ext.105111Ext.111101Ext.101@[Dev:sip:110@192.168.1.91:5060]
    19:34:30.044
    [CM503010]: Making route(s) to <sip:801@169.254.56.187:5060>
    19:34:30.042
    [MS210000] C:23.1:Offer received. RTP connection: 192.168.1.95:5020(5021)
    19:34:30.037
    19:34:30.037
    [CM505002]: Gateway:[GWX 4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:4) 1.3.4.7] PBX contact: [sip:10003@192.168.1.51:5060]
    19:34:29.966
    [CM503001]: Call(23): Incoming call from unknown@(Ln.10003@GWX 4104) to <sip:801@169.254.56.187:5060>
    19:34:29.932
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10003 forwards to DN:801
    19:34:29.929
    Looking for inbound target: called=444; caller=unknown
    19:34:29.905
    INVITE sip:444@192.168.1.51 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.95:5064;branch=z9hG4bKa83417e34f95bcc1
    Max-Forwards: 70
    Contact: <sip:10003@192.168.1.95:5064;transport=udp>
    To: <sip:444@192.168.1.51>
    From: <sip:unknown@192.168.1.51>;tag=23763860202790c2
    Call-ID: 57e47bb29a012b7165e574d179f43907@192.168.1.95
    CSeq: 9025 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK
    Proxy-Authorization: Digest username="10003",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:444@192.168.1.51",nonce="414d535c02e24a4514:c577d054386858fa9567009ef9e348f1",response="e29318577a22ebcaef3c45495585197c"
    Supported: replaces, timer, path
    User-Agent: Grandstream GXW4104 (HW 1.1, Ch:4) 1.3.4.7
    Content-Length: 0
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    - Check whether you've actually enabled recording on your new installation on your extension's settings.
    - Check Settings > General > Global options > Recording Path and set it a location of your liking.
    - Check Settings > General > Mail Server and see whether the settings you have entered there are correct.
  4. Jonners59
    Apr 21, 2009
    129
    LeonidasG
    Many thanks for this... I resolved the saving messages... It would seem that, and logically the path to save the files disappeared. The field was blank, and after so long since I set things up, I forgot it was there. And what was great, all the messages we had missed were there too!
    Sending via eMail. That was not so good though.
    I use gMail, So the server is smtp.gmail.com
    Username is the eMail address and corresponding password. However it uses TLS encryption.
    Therefore to make it work, I had to use the smtp of my ISP. Not as tidy, but it worked.
    Many thankshttp://www.3cx.com/forums/posting.php?mode=edit&f=1&p=89874#
  5. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    I had put in a feature request about TLS mail.
    As 3cx are using .net to write the program and .net has an ssl/tls setting it should be fairly straightforward to add the feature but i suspect it is lower on the priority list.
