Loud FAN noise Every 10-15 Minutes with Debian for 3CX
Discussion in '3CX Phone System - General' started by sac9829, Apr 3, 2018.
  1. sac9829
    Feb 26, 2018
    14
    Just wanted to check if anyone else has noticed any issues when using the Debian for 3CX (Running version 15.5.0)
    With the following Intel Rack Mount Server:
    R1304SPOSHBNR - https://ark.intel.com/products/97951/Intel-Server-System-R1304SPOSHBNR
    As noticed everything seems to work fine but every 10-15 minute the server fan seems to roar to life for 5 seconds and then goes back to the normal running sound level.
    Have another exact same server with Windows Server 2016 on it and it doesn’t have this issue.
  2. andrew_
    May 28, 2017
    I would potentially install lm-sensors and see if anything is reporting its temperature strangely.
    Would also check if there is a BIOS update for the server and run that. Might be some weirdness between Debian and the host.
    Also, if it has iDRAC, check that and see if any strange meter readings/alarms
