Loud Ringing Device
Discussion in '3CX Phone System - General' started by craigbrass, Aug 5, 2008.
  1. craigbrass
    Jul 10, 2008
    7
    Is there such a thing as a device that simply rings loud that I can connect using SIP to 3CX so that it alerts staff when they are away from their desks to a new call? I know traditional PSTN had such devices but does SIP have an equivalent?
  2. AJAY
    Jun 17, 2008
    7
    Use an ATA with a loud ringing device connected to it in place of a POT.
    Add to ring group with other relevant extensions and there you go.
