loudspeaker or shop paging for 3cx
Discussion in '3CX Phone System - General' started by zooeyhall, Dec 8, 2009.
  1. zooeyhall
    Apr 15, 2008
    42
    We need a loudspeaker/paging system in our shop area to work with our 3cx Small Business system. Our old PBX had a speaker system that worked as an extension on the phone system. I am assuming they make something like this to work with an IP-based PBX?
    Can anyone advise on brands or where I might buy a system, that I know will succesfully work with 3cx? I've been searching on the Internet but can't seem to find exactly what I want.
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Check out our selection of products from Valcom, they have a wide range of products for paging and intercom.
    http://www.888voipstore.com/valcom
  3. scott
    Jul 30, 2009
    27
    Kerry - are there any ATA type devices that can be tied to the existing Valcom paging zone controller? Most of the Valcom adapters I have seen auto-answer an incoming analog call.
    Scott...
  4. KerryG
    Jun 19, 2009
    960
    What exactly are you trying to accomplish with it? A speaker/pager is going to auto-answer like an extension and some provide two-way conversations.
  5. viper
    Jan 27, 2010
    20
    Hi, Snom have just released the Snom PA1 (http://www.snom.com/en/products/sip-paging/snom-pa1/) which should meet your requirements. If you want pricing let me know.
    Thanks, Tom
    Viper IT
    08445 000 333
  6. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    663
    You can set 3CX VoiP Phone in Auto-answer mode and connect standard Speaker Amplifier to PC soundcard Audio-out
  7. KerryG
    Jun 19, 2009
    960
    That seems like a little overkill to have a complete PC being used as a paging device when you can buy SIP amplified speakers.
  8. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    3CX PBX is running on PC... Lineout is available...
  9. KerryG
    Jun 19, 2009
    960
    Assuming that you want to run wires from the PBX to where ever the speaker is and that you have a sound card in the PBX server, plus now adding another piece of software on the server that is always running and that you need to make sure is always up. While it seems simple, it still isnt the best option in my opinion. I would rather use a real SIP amplified speaker and avoid the extra hassle.
  10. igor.snezhko
    Jan 7, 2008
    663
    Many companies just have some analog paging system installed, so my solution is simpler for them.
  11. KerryG
    Jun 19, 2009
    960
    In your case I might use a snom PA-1 or a Valcom gateway to interface properly with their existing analog system. If you are trying to save money, then yes, your solution is more cost effective but not as 'elegant'.
