low ring tone with Google NEXUS One
Discussion in 'Android' started by ajnaro, Jan 3, 2011.
  1. ajnaro
    Jan 3, 2011
    There seems to be a software issue between 3CX and Android 2.2.1 FRG83D on my NEXUS ONE: when 3CX is running the volume of the incoming ring tone is inaudible. When I force 3CX to stop, the incoming ring returns to normal volume. Is there some way to fix this?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    This is a bug in the 3CXPhone, it's logged on our bug tracker and is something we plan to fix.
    For now unfortunately there is nothing we can do about the issue you are having.
  3. ajnaro
    Jan 3, 2011
    Thank you for your reply. Please try to remember to post here when the bug gets fixed. Until then, it's sorta impractical to use 3CX, at least on the NEXUS One.
