Low Voicemail Recording Level
Discussion in '3CX Phone System - General' started by iamgreen, Mar 11, 2008.
  1. iamgreen
    Sep 25, 2007
    52
    I noticed that the recording level for voice mails is very low when sent as .WAV attachments to my SMTP mailbox. They are so low that when I play them back I crank the media player mixer up all the way and I can faintly hear the message. Has anyone seen this before?
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    can you tell me if that happens all the time with different users or is it just so now and then.
    Do you listen to the voicemail on the same computer as the 3CX system or do you listen to it on a computer where the message is mailed to. How is the voice volume level when you listen to it from a phone?
  3. iamgreen
    Sep 25, 2007
    52
    At this point it seems like a once in a while thing. I just left a voice mail for myself and the recording level was just fine.
  4. landfiets
    Jul 17, 2007
    243
    take a look at the soundcard of you 3cx system if that volume is high enough. update drivers of soundcard.
  5. iamgreen
    Sep 25, 2007
    52
    My 3cx server doesn't have a sound card.
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    incoming stream is saved "as is". Do you have the problem with "music on hold is too loud"?
  7. iamgreen
    Sep 25, 2007
    52
    Nope, the music on hold seems to work fine.
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Do you hear the "high volume of noise" if you are talking with "source of low volume VM"?
