Low volume linksys spa3102 & caller id voipbuster
Discussion in '3CX Phone System - General' started by carmico, Dec 18, 2007.
  1. carmico
    Oct 11, 2007
    23
    1. How to setup the conversation's volume on linksys spa3102 as pstn line gateway ?--- because is too low.
    1.1 How to setup the music-on-hold volume on 3cx? because is too high..
    2. how to setup the outgoing call caller id for voipbuster? i set in 3cx the outgoing ID but doesn't work, still private id.
    thanks,
    Carlo
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Hi, about your 1 question, log into your SPA has admin, go the pstn line configuration, on the bottom you will see SPA to PSTN and PSTN to SPA gain, change those values to get higher or lower volume, be careful thoug, if this values are too high it can create echo during conversations.
    Question 2, has far has i know, not possible
    Question 3, has far has i know, not possible either....
    Cheers
  3. subh
    Dec 4, 2007
    28
    For Q2 --> open the on-hold music file in a wave editor and lower the volume and save it as another file. Use that new file as your on-hold music.
    Hope this helps.
  4. carmico
    Oct 11, 2007
    23
    yes, thanks for the solutions!!!
