Low volume when calling to a mobile
Discussion in '3CX Phone System - General' started by GonzaloS, Feb 20, 2018.
  1. GonzaloS
    Feb 2, 2018
    11
    I am redirecting calls to a mobile and the sound is very low in both ends. I was wondering if it is possible to increase the volume from the configuration of 3cx?
  2. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hi GonzaloS,
    The PBX by default does not manage call volume what we receive is what we send from the endpoint. You can only change the volume from the endpoint you are using.
    Are you having this issue only for one particular device?
    When you say redirecting you mean you forward a call to a mobile using forwarding rules or are you transferring a call that was initially answered by an extension?
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Or if you are using GSM Gateway take a look in the settings of that gateway.
    I've experienced same thing with some GSM gateways and solved it with adjusting volume on that particular device.
