Lower/Mute Sound Volume on Call
Discussion in 'Ideas' started by Lev, Oct 22, 2015.
Lower/Mute Sound Volume on Call 5 5 2votes
5/5, 2 votes
  1. Lev
    Lev New Member
    Sep 19, 2015
    122
    18
    It would be pretty convenient, if 3cx would lower the sound volume of other programs when picking up or initiating a call.
    Options:
    - Select the volume of other programs (0 - 100%)
    - Change volume on ring or just when a call is already established
  2. Silly English Kniggit
    Sep 13, 2017
    220
    89
    I completely agree.
    If it's music - you can work around it by having 3CX trigger an external command to pause the player. One way is to find a copy of CLMControl.exe (see http://greatcanadiannerd.com/index.php/turorials/voice-attack-software or compile from https://github.com/InvalidCastEx/CommandLineMedia) and in 3CXPhone go to Cog menu > Advanced Settings > Behaviour > External Application
    Check the Launch button and enter the path to the exe and the command line for your player etc. For Spotify the parameters "spotify -pa" works wonderfully.
