Mac / OS X Client & Multiple Accounts
Discussion in '3CX Clients' started by AH2, Sep 13, 2017.
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Hi There,
    I've been having problems with the OS X Client and multiple accounts.
    If I have more than 2 account ( different 3cx servers ) on the OS X client after a few seconds the client always goes to "Service Unavailable", I can see presence, and send chat, but not incoming/outgoing calls.
    When I remove all accounts just leave 1, no issues.
    [​IMG]
    Thanks,
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
    Hello @AH2
    Do you mean you have 2 accounts running simultaneously or you have 2 accounts under the 3CX client and run one each time?
    AH2 likes this.
  3. AH2
    AH2 New Member
    Mar 14, 2017
    112
    No, from what I understand, you cant have multiple accounts connected simultaneously. I mean both accounts have been registered/added to the 3CX client.
    Now since yesterday I've removed all accounts, and added back just 1 of them, the issue still persist, I have to re-register, or close/open the app several times in 1 hour to keep it hooked.
    any ideas ?
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    "Service unavailable" is not, let's say, an usual error. One of the few reasons is tunnel disconnection - please try to uncheck the "Use tunnel" option in account settings (and uncheck the "re-provision on startup" to prevent override) and tell us if the phone is working OK. Btw, what's client version (as shown in About)?
    vali
    AH2 likes this.
  5. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Hi, it seems to have stopped going into "service unavilable", not changes at all, will monitor and see what happens.
    But yesterday was happening within seconds of hooking, over and over.
    [​IMG]
