Mail Server
Discussion in '3CX Phone System - General' started by igpetkov, Feb 25, 2015.
  1. igpetkov
    Feb 25, 2015
    25
    I have a problem with Mail Server. I can't send welcome e-mails and notifications.
    I use this e-mail with Thunderbird and everything is fine (send and receive messeges), but I want to use this account for my 3CX PBX to send welcome messeges and notifications. Try to enable SSL/TLS but do not succeed. Try to specify port 465 doesn't matter. I attached screens with account settings in Thinderbird and screen from 3CX PBX.
    I will be glab for any help. Thank You.
    If someone use gmail or other free mail server, let share his expirience
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    51
    Did you tell 3CX who your e-mailprovider is?
    Settings > General > Mail Server
  3. igpetkov
    Feb 25, 2015
    25
    Yes, I enter mail server, user name and all other data - same as thunderbird account.
  4. complex1
    Jan 25, 2010
    832
    51
    As far as I know you have to specify the port number if you don’t use the default SMTP port number 25.
    If you enable SSL/TLS or use another SMTP port you also have to specify the port number in the Mail Server field. In your case something like mbox.contact.bg:465 or mbox.contact.bg:587
  5. igpetkov
    Feb 25, 2015
    25
    Yes, I try what you say, and posted screens, but I make again and post results again:
      File size:
      150.1 KB
      871
      File size:
      153 KB
      871
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    I had that same error message once trying to use IIS SMTP Server.
    I changed to an Office 365 connector and it went away.
    I never had time to wireshark it, but was happy using 365 for transport.
    A wireshark log may give a better error.
  7. igpetkov
    Feb 25, 2015
    25
    Thank You for your posts. When I have a time may try Wireshark. Is any use free mail server like googlemail for mail server? I will be glad to share his expirience in that forum . Thank You again
  8. igpetkov
    Feb 25, 2015
    25
    I do not succeed to establish connection with smtp server of my ISP, and decide to use gmail. I attach screen with smtp settings of gmail.com
