Mailing alerts...
Discussion in '3CX Phone System - General' started by dozer, Mar 5, 2014.
  1. dozer
    Mar 5, 2014
    HI all,
    Is there a "test the mail" button when setting up the e-mail notifications ?
    Be good to know if it's working!
    Doz
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    There is not a "mail test" button per se, but it is still enough to test. Simply go to the Extensions page and select an extension with an email address (likely your own) and then do the pull down at the far right and send yourself the welcome email.
