Main Menu with direct extension dialing
Discussion in 'Call Flow Designer' started by Mark Ibiaz, Sep 25, 2017.
  1. Mark Ibiaz
    Jun 28, 2017
    Hello everyone,
    i am a little bit stuck right now in trying to implement a main menu with direct dialing extensions like in the digital receptionist.We wanted this so that we can setup transfers to the correct people during certain hours. Thank you
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,449
    115
    Hi @Mark Ibiaz,
    In that case, instead of using a Menu component, you need a User Input component. The Menu component will only ask for 1 digit, and move on. If you need to let the user enter for example 3 digits for the extension number, you need a User Input component. Then, in the Valid Input branch you can use a "Create a condition" component to decide if the user input is a menu option, a valid extension, etc.
    In order to check if the input is a valid extension, you will need to use the 3CX Call Control API, from a Launch External Script component.
    Kind regards.
  3. Trestill
    Jan 22, 2015
    46
    Hi Mark,
    from what you are saying it looks like User Input component should do and then Transfer Component to userinput1.Buffer.
    You could add Condition to check if extension of provided number exists (and is willing to accept direct calls).
    Regards
  4. edossantos
    Jun 27, 2007
    1,449
    115
    Hi @Mark Ibiaz,
    In order to check if an extension is valid or not, you can use:
    PhoneSystem.Root.GetDNByNumber()
    That method will return null if the extension is not valid.
    Regards.
