Major Problem
Discussion in '3CX Phone System - General' started by jmatson, Apr 18, 2010.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    Just started today.
    when someone calls in. i get a error msg saying A error occured in IVR session sorry. I get the same error when i dial that ext
    I also can't call VM same error msg
    I can make outbound calls.
    There is nothing in the logs that look out of place
  2. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    All services are running. i have restarted them no luck. i have restarted the server no luck
    i am looking at System Ext everything is running. I can dial into a conf. But not IVR or VM
  3. pcunite
    Apr 12, 2010
    29
    PBX is complex software and 3CX makes a nice GUI for such a complex thing. As much as it hurts you might have to slow down and througly look into to how to setup it up. It took me a few days.
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    can you please send me all the logs in verbose mode please.
    Also what operating system are you using and which web server,
    IIS or Cassini?
  5. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i reinstalled 3cx and it's working now.
  6. Montclairguy
    Feb 23, 2010
    68
    If you're running Cassini, this is the logging bug that prevents Cassini from starting. Read this thread for the solution:
    http://www.3cx.com/forums/cannot-start-the-web-server-8649.html#p72599
    After you clear the logs, restart the Utildev Cassini webserver.
  7. mchristsen
    Mar 30, 2010
    26
    I had the same problem with a Windows 2003 x64 installation on IIS. No matter how many times I reinstalled it would not work. I finaly installed 3CX using Cassini and all is well.
    Michael.
  8. rrable
    Jul 13, 2010
    7
    This happened to us again this morning. twice in two weeks now after system had been running smoothly for a couple of months. A caller calls in and received the message "an error occured in IVR session sorry" then is disconnected. this is a latest version 9 install with abysis. Any ideas?
    Randy
  9. ayachem
    Oct 1, 2009
    19
    I tried several suggestions from the forum without success, but I got it working by just restarting the Abyss service. In our case the IVR suddenly stopped working overnight.
